Automatic Condensate Removal Pump replacement
Old 06-03-12, 09:17 PM
R
The 5 year old Automatic Condensate Removal Pump for my TRANE 5 Ton 16 SEER Heat Pump Unit will not shut off automatically anymore.
Are there any maintenance options or should I just replace the unit?
Any special requirements for the replacement or will any readily available Ac unit do (like 1/50 horsepower 115 volts) ?
Thanks,
Rainer
Old 06-04-12, 09:55 AM
F
Received 36 Votes on 28 Posts
There is a float operated switch inside the pump enclosure. Make sure it moves freely. They sometimes have the hinge pin fall out.
Old 06-04-12, 04:18 PM
R
Thanks,
that did the trick!!
Old 06-04-12, 09:53 PM
F
Glad it was that easy. Thank you for letting us know the outcome,
