Portable home AC units
Old 06-21-12, 07:45 AM
W
Received 1 Upvote on 1 Post
I have a couple of questions about portable (roll around) AC units.
The specs for the one I bought says under normal use the unit evaporates the condensate and should not require emptying. The 1.5L "emergency" condensate tank on mine requires emptying every 8-10 hours and it is a real PITA. Is it realistic to expect an AC unit to cool the room all the while recycling the humidity that it is removing?
Question #2 Are all portable AC units very noisy? Mine is advertised at
<45 dbA. I don't have a way to measure sound pressure but my ear tells me that the spec is way off base. I suspect it is the way the measurement was made. It seems to make sense that a unhit entirely within a room will be much louder than a unit tha is mostly hanging out the window.
Old 06-21-12, 08:03 AM
Received 1,190 Upvotes on 1,147 Posts
Wayne: I'm no HVAC pro but I agree with your thought process - how can the AC dehumidify the room if it evaporates all of the moisture it removes back in to the room?
Old 06-21-12, 10:54 AM
user 10's Avatar
Received 52 Upvotes on 46 Posts
The moisture evaporates into the exhaust.
Contact the manufacturer since it's not working as it should.
Old 06-21-12, 02:47 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Is your unit a one or two hose unit?
Old 06-22-12, 08:14 AM
W
Tolyn - It WAS a one hose (6") unit. I returned it today. I won't mention the brand but even if it had cooled the room to sub zero I would have returned it. It is advertised as <45dbA yet it sounded like a B-17 and touted as only requiring condensate emptying in "emergency" circumstances which the manual defined as a very cold, damp room. Well, the 1.5L emergency tank filled in just a few hours and it was a serious PITA to empty.
I replaced it with a wndow unit recommended by Consumer reports.
