what the better condenser
Old 06-21-12, 04:37 PM
P
my supplyer has
coaire
comfortstar
goodman
i need a middle of the road 13seer 2ton ac only condenser. i think all 3 have a scroll comp. and high and low safe swiches.
i dont need a high seer, as i have a unico system
thanks
Old 06-21-12, 06:43 PM
R
goodman is what i mostly use. strong warranty, easy to install
Old 06-21-12, 07:38 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
All low end equipment and I'd bet come with a low end install. I'd find another company.
Old 06-21-12, 09:10 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
The quality of the install is what counts.
There's nothing wrong with 13 seer, but 14 seer models sometimes come with better compressor protection (prevents damage in the event of a problem) and sound insulation.
Be sure to get the full model number of the evaporator coil and condenser unit.
Old 06-23-12, 03:35 PM
P
condenser
what unit would you install with a unico syatem then? the system is already installed just need the outdoor unit.
Old 06-24-12, 02:18 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Is the unico designed for R22 or R410A? This is very important for you to know when making that decision.
Old 06-24-12, 03:59 PM
P
unico
it has the 410tx valve. im not to worried about efficency, as i have solar pv that produce 120% of my power. Its got to be better then my 2 window shakers now. just want middle of the road, with a scroll compresser, and high and low safety switches
Old 06-24-12, 04:02 PM
hvactechfw's Avatar
then brand does not matter it is all about the install. Choose any brand you want with those items.
