Have I just destroyed a 500$ 2 year old Kenmore 18k BTU Air Conditioner??
Old 06-23-12, 07:54 PM
C
so, the front panel was missing a screw
I went and got one, unfortunately just a bit to long.
idiot.
It punctured one of the coils on the evaporator, right near the side of the unit, tiny little hole but big enough. Hsssssss
So, I called sears. New evap is ~$100, plus a couple hours of labor minimum. Somewhere between $300 and $400.
I dont see why it can't just be fixed, but poking around and I see that it needs to be brazed not soldered. I have sweated many, many pipes. Used to be a carpenter. Looks like I can get cheap brazing torch, fuel and some silver brazing alloy for
Old 06-23-12, 10:25 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
It mostly will cost more to fix it. You will need a dryer $15, and a couple of service valves $10 both at cost nitrogen, vac pump, plus a tech for 3 plus hours at $65 plus an hour then refegerent.
Old 06-24-12, 11:21 AM
user 10's Avatar
Received 57 Upvotes on 50 Posts
Not worth fixing unless you can get someone to do it for free.
Old 06-24-12, 01:47 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
you cant charge the system yourself which will cost as others have said... its not worth fixing. Put it on Craigslist and someone that can fix it cheap will buy it. You wont get much for it though.
Old 06-24-12, 06:44 PM
C
ARRRGGGGHHHH
well, thanks for the replies.. any thoughts on how long it will take to live this down?
Old 06-25-12, 04:22 AM
Received 851 Upvotes on 747 Posts
..... until you make the next mistake or complete a well done needed job around the house
btw - welcome to the forums!
