AC outside unit
Old 06-28-12, 11:10 AM
AC outside unit
Hello, I was running the AC in my house for the past few days, yesterday I try to turn it on and it didn't, I went outside and I heard a buzzing noise in it. Any suggestions?
Thank you.
Old 06-28-12, 04:02 PM
C
Received 6 Upvotes on 6 Posts
Sounds like the contactor problem, but we need more info to be sure. did you open the condenser panel to check it ?
Old 06-28-12, 08:03 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check your breakers and disconnect for fuses.
Old 06-28-12, 08:13 PM
I checked the breakers, breakers are good,checked the two fuses, they are good, where and what am I checking at the condenser panel?, when I turned it on it wasn't a constant buzzing, I heard a click and then like it wanted to start, I moved the fan blades with a stick and they moved freely.
Old 06-28-12, 08:18 PM
hvactechfw's Avatar
do you have a volt meter and know how to use it? Remove the panel and verify the contactor is pulled in with a call for cooling. Check the capacitor for swelling.
Old 06-28-12, 09:12 PM
I do have a volt meter, I don't understand what you mean when you say to verify if the contactor is pulled in, may you please elaborate. Thank you
Old 06-29-12, 10:05 AM
hvactechfw's Avatar
Google contactor and you'll see what I'm talking about when you see it in your unit.
Old 06-29-12, 06:20 PM
The capasitor is swollen, I checked the voltage in the contactor and it read 240 V. If it is the capasitor, is there a place that you recommend to buy it?
Old 06-29-12, 10:16 PM
hvactechfw's Avatar
Anywhere.... but grainier is located I have most places or close by.
Old 06-30-12, 03:12 PM
is it a good idea order it online?, or it is best to look for a store?, any idea how much is the price for those?.
Old 06-30-12, 03:16 PM
hvactechfw's Avatar
go to a local motor shop or buy it online, it does not matter. A capacitor is a capacitor and they are common. Average cost is $30 - 50 retail.
