Dripping HVAC Expansion Coil Case
Old 07-02-12, 07:23 AM
V
The case around my "A" Coil drips like crazy when the outside temp is in the +90s and Heat Index is in the 100s. I have a 12 year old 4 ton outside 9.5 SEER condensing unit and an five year old air handler with a "A" coil upgrade to support 13+ SEER if I ever replace the outside unit. Is the dripping normal in high humidity conditions as I describer?
Old 07-02-12, 09:33 AM
E
No. Probably have a partial blockaga on the pvc drain line
Old 07-02-12, 10:41 AM
V
Dripping Case
Guess I need to try and clear the blcok, air pressure or take apart and scour?
Old 07-02-12, 12:51 PM
V
Dripping Case
I obviously did not phrase my question well. What I meant was the case is sweating like a can of soda or beer taken out of the refrigerator and opened so that beads of moisture form on the can.
Old 07-02-12, 07:34 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
the case should be insulated if it is not in a conditioned space. If it is in a conditioned space then you need a dehumidifier.
