Hiome AC unnit question
Old 07-02-12, 08:51 AM
We have carrier unit,the compressor locked up:
do we have to get the whole condenser replaced or just compressor?
if the whole condenser need to be replaced: do we have to use Carrier condenser or we can use any other brand name?
if the compressor needs to be changed out: do we have to use the same compressor as the one on the unit ?
Thanks
Old 07-02-12, 10:39 AM
user 10's Avatar
Upvotes Received: 20
If the unit is less than 12 years old and in good shape, the compressor can be replaced.
If it's old, you'll be much better off replacing the condenser unit and indoor coil.
Read more: http://www.doityourself.com/forum/ai...#ixzz1zUJGrS9R
It's very important to use an approved indoor coil/air handler.
Don't let anyone reuse the old coil if you choose to replace the condenser.
The newer units require larger coils and use a different refrigerant.
Old 07-17-12, 09:46 AM
thanks for hour input................................................................................
