Caulk around air return?
Old 07-02-12, 02:28 PM
A
Our upstairs air conditioning unit is in our basement and sits on the concrete slap. The return air duct connects to the bottom. However the bottom has a small gap where it meets the concrete and air is getting sucked in through there all around the edges. Should I caulk around this with silicone? Pictures with notes...
Old 07-02-12, 03:21 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
Sure, why not?
Old 07-02-12, 04:13 PM
A
Not really sure on the "Why not?" part. I just wanted to make sure there were no disadvantages to plugging up basically any leakage I can find. The original installers obviously did a bad job sealing the entire system up and I just wanted to check.
Old 07-02-12, 06:40 PM
user 10's Avatar
If the ductwork is severely undersized, sealing up leaks may cause problems.
Otherwise, it's a good practice.
