outside unit issues
outside unit issues
i have a 5 year old ducane outside unit,about 3 years into its service the capacitor(dual cap) died,i have buying ebay capacitors every 6 months or so for the last 2 years.yesterday it died again and i bought a new capacitor locally this morning and installed it,no go.if i understand correctly these capacitors run a motor in the unit,is it the fan motor or is there another motor i dont know about.without getting into specifics of the unit,can ya`ll give me some ideas on what to look at.thanks
a friend told me to put an amp clamp around the wires leading to the unit and put the thermostat super low like around 60 and read the amp draw,when i do this what should the amp draw be to indicate whether or not im pulling to many amps out of the unit?thanks
Amp draw can tell you if your fan motor and compressor are still in good shape, but that is not the way we test the capacitor. If a good run capacitor can not start your unit, and the amp draw is high, you may need a hard start kit. but one step a time. first, you need to get the unit up and running first. (there is a possibility you have other problems, not capacitor related)
