Carrier variable dc motor thermistor
Old 07-06-12, 08:40 AM
E
Where can i buy these things. They arr black and about the size of a half dollar. Used in dc variable speed motor
Old 07-06-12, 11:08 AM
user 10's Avatar
Received 57 Upvotes on 50 Posts
Electronics supplier?
Old 07-07-12, 08:29 PM
Received 1 Upvote on 1 Post
Is this a GE programmable motor with a 5 pin and 16 pin connector?
If so, I just replaced mine (Trane, but has same motor) with a Honeywell ICL321R030-01. DigiKey had the best shipped price on it at $8 and change. The original one in the motor is rated for 10A max (the motor nameplate rating is 9.6A), this part number has a 30A max rating, so it shouldn't burn out on you again. I have a suspicion that the original part is intentionally undersized so that it burns out just outside the warranty in order to drive replacement part and labor sales. The control module alone for that motor is over $450.
ICL321R030-01 Honeywell Sensing and Control | 480-3177-ND | DigiKey
