central AC is cutting out
Old 07-07-12, 08:35 PM
D
hello, i have two central AC units outside for two zones. recently there was a power outage and one of the units did not want to turn back on. although the breaker was not flipped i reset it after i turned the thermostat off, essentially rebooting the system i believe. it worked but the same unit is now cutting out sporadically. i can't figure out why. i replaced the thermostat so that's out. i even cleaned the condensor. any thoughts?
Old 07-07-12, 10:47 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Swollen dual capacitor in the outdoor unit...
Common after power outages and storms.
Old 07-22-12, 08:15 AM
D
it turns out the condensation pump was clogged and stuck so the kill switch was engaging and cutting the AC out. my next issue is the fan for the other AC unit i have will not turn off. it blows constantly. any thoughts here? i'm guessing it's a fan switch or pressure switch
Old 07-22-12, 07:24 PM
E
It blows what constantly? Indoor motor? Its the relay on the circuit board.
