Is this freon leakage?? with pictures! or what is it??
Old 07-10-12, 04:11 PM
C
AC repair person told me i had freon leakage but i didnt get it fixed. Here are some pictures. Can anyone tell me what is that?
Pictures:
1. Name:  IMG_05112.jpg
and this one is a different unit....i dont know what this one is leaking
2. Name:  IMG_05122.jpg
Old 07-10-12, 04:28 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
That looks like dried up condensate. The insulated line needs to insulated all the way to the coil.
Old 07-12-12, 01:44 PM
I'm going to agree. That looks like normal condensation that has evaporated. Freon is a gas. The dripping is under the water drain, and is in a catch pan. Did the repairman check to see if you had a Freon leak, since that is what he thought it was?
Old 07-12-12, 01:57 PM
Received 1,288 Upvotes on 1,226 Posts
You can't see a freon leak, can you?
Old 07-12-12, 01:59 PM
hvactechfw's Avatar
Mitch
You can see oil residue left by a refrigerant leak.
Old 07-12-12, 02:23 PM
Dang, I let my ignorance show on that one. Thanks.
Old 07-12-12, 09:29 PM
C
So is it a freak leak? I know you cant see it but does the oil residue mean the leak is there. I had it inspected early but just decided to fill the freon up. The freon was empty when they inspected it.
Old 07-13-12, 12:45 AM
F
Received 39 Upvotes on 31 Posts
If there was little or no refrigerant in the system AND the tubing or drip pan had an oily reside then yes, there is (or at least was) a leak at that point.
Old 07-13-12, 06:06 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
As said, residue from a refrigerant leak will be oily.
If your evaporator coil is before the fan as in the fan drawing through the coil you may have problems with your drain line as no trap can be seen in your pics.
The negative pressure in the fan cabinet can cause air to flow backwards in the drain line preventing water from draining.
Also, during days of extremely high humidity the moisture flowing across the coil can increase the negative pressure across it causing water leakage on these days.
If your coil is before the fan you could eliminate leaking by installing a trap.
