Condenser fan seems too fast, makes louder hum than before...
Old 07-11-12, 08:49 AM
Hello all,
First some background on my issue. I had zero experience in HVAC, but after reading many posts on this forum, I was able to replace my capacitor and condenser fan motor (motor was overheating after 30-60 min of use). I replaced it with a motor of the same type (Fasco D7909 1/4 hp, 1075 rpm) as well as a matching capacitor (50/7.5 mfd, 440 VAC 50-60 Hz dual capacitor). The wiring was a bit difficult since the colors of the old motor did not match the new.
After hooking it up, I was still having issues with overheating on occasion. I realized yesterday that I had the white and black wires backwards, and swapped them. Since then, the motor is definitely working, but seems to be too fast, and is humming louder than before. I could just be wrong about it being too fast, but I definitely think the hum is an issue. Could I have bent one of the fan blades during installation, and if so, how do I test that?
(Edit: I also had an issue with the fan going in the wrong direction sometimes but not all, which is how I figured out that the white and black wires were backwards...)
Thanks in advance, any info would be appreciated. As I said, I am new to this type of maintenance. Sorry for the long post, wanted to give as much info on the issue as I could.
Old 07-11-12, 05:57 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
most likely you have the capacitor wired wrong. Please post your wiring to the capacitor.
Old 07-12-12, 02:37 PM
Thanks for the response hvactechfw. It turns out the fan was just mounted lower than it needed to be, this is what seemed to be causing the extra noise.
