My thermostat melted down
Old 07-11-12, 08:49 PM
G
I got up and turned on my air conditioner like I do everyday and it didnt come on. Found out it blew the fuse. So I replaced the fuse and turned it on and my thermostat started smoking. Turned it off. It melted down my thermostat. I dont know how to troubleshoot what the problem could be so I need help. This is an old unit. It is an air conditioner/heater but the heater part does not get used. I cant see a name on it but the model number is 7655856. On the blower motor it reads, 900759 Heating/Cooling Blower Motor. and It just says air conditioning inc. Under that. Im hoping I can get some good advice here. Thanks
My thermostat is a Honeywelll digital RTH110B and its a 4 wire.
Old 07-11-12, 09:15 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
I've seen a thermostat melt when 240 volts is shorted to the 24 volt circuit.
Probably need to call a pro.
Old 07-11-12, 10:44 PM
G
So that would mean the transformer went bad, right? Can you tell me how to test it?
Old 07-12-12, 04:22 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
it may mean that wires shorted in the a/c I would start by looking there.
