the cold air seems to be blowing through the OUTDOOR unit, inside won't cool
I checked the wiring on the thermostat, it's correct. Don't know enough to know if something is wired incorrectly inside the unit. The outdoor insulted pipe does NOT get cold when the unit is on. The fans run. The run capacitor tests fine. How do I know if the compressor is running? The unit fires up and seems to make all the proper noises. I have 2 units. The one next it runs fine - the air blowing through it's outdoor unit is warm and the large insulated pipe is cold with condensation. The non-working unit is blowing COLD air outside and large pipe is warm. WTH? The coils on the outside unit are clean. Not sure how the clean the coil on the inside unit. Not sure if that's the problem. I've read the threads and don't see anyone having this issue. I'm at a loss. If it matters ... this is the unit that runs the upstairs and isn't used all that often - although I do turn the fan on to keep the cool basement air flowing upstairs. Girl on a budget here. I'm pretty handy but this is a bit over my head.
Is this a heat pump or air conditioner? What made you check the thermostat wiring? Have you just installed a new thermostat?
it's an AC. It's not a heat pump - which is a relief because I just learned about reversing valves and that had giant dollar signs written all over it. I checked the themostat because it was replaced last year. The heat works, the fan works ... the wires appear correct according to the diagram.
