AC cuts off after half hour, requires heat turned on to get AC to turn on
Old 07-17-12, 04:25 PM
A
Okay, the AC or furnace might be about to call it quits, or it just might be a small issue (my hope). I think it might be a furnace blower issue, but I'm not sure.
So I noticed it was getting warmer, but my furnace was still running. I go outside, see the AC isn't running. I turn the furnace off and on, nothing happens. I change furnace to heat, and get that going for a few moments, then I switch it back to cool and the AC kicks on. I have had to do this twice, and both times this has made the AC come back on. So would this most likely be a furnace issue, like the blower?
Any suggestions on what I might be able to look at and attempt before I call someone to look at my system?
Old 07-17-12, 05:34 PM
E
Its definately not the blower. However, I do suspect the problem is in your furnace. The circuit board may be malfunctioning. instead of going to heat, next time go to the furnace, turn it off, wait 3 minutes, then turn it back on. I suspect you are losing 24volts when the ac goes off. And that 24 volts comes right from Y and C on the circuit board in the furnace. I suspect C to be the problem. Dont ask why. But if you have a way to check voltage, check it.
Old 07-17-12, 05:40 PM
A
Okay I will give it a check, I do have a voltage checker.
So far the air has been blowing for 2 straight hours
Old 07-18-12, 08:04 AM
A
Oddly enough, I haven't had any issues with this since I got it running for the second time. It has been on for over 17 hours turning off and on on its own!
Old 07-26-12, 04:35 PM
A
Okay, so I'm having issues again, if this is the case, that I'm not getting enough volts at one of those places, does that just mean I need to replace the board?
