Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Air Conditioning and Cooling Systems
Reload this Page >
A/C compressor fan not coming on, but free. Hear a click, and very quiet hum.
Old 07-18-12, 05:17 PM
B
I have the apparently very typical "compressor clicks" observation, but when i spin the fan with a screw driver after it clicks, the fan just spins free a little bit and doesn't engage a motor or anything. I'm mechanically inclined and with time can manage to figure most any problem out, but I'm here visiting family so my time is limited and its raining out today.
my gut says the fan motor is gone, but as i have zero experience with any type of residential air work, i hoped to find an experienced friend here to lead me.
i have a window right by the outside unit, so when i'm out there, i have another person in the house switch the tstat to cool. when that is done (i can't see them, so i don't know if there is any time delay) i hear a "click", and that is all; other than the very faint hum, that my limited ear would compare to a seized (small-because of how faint it is) motor. like i said though, the fan moves freely.
i just went out and pulled the panel when we got a little break in the rain. the model is a trane xe1000. i noticed a small red led blinking (i've flipped the outside breakers off) and i noticed one of the hot in's (red) were melted and corroded on both sides of the wire nut. appears to have been that way a little while. I don't have any heavy romex on hand to replace that immediately, but since it seemed to be working last night, and there's corrosion on the exposed wire, hopefully we can diagnose a problem beyond that---even though it would be amazing for it to be something that simple.
i don't know what questions to actually ask, so hopefully you'll know diagnosis orders to bark.
thanks a ton for any help! even with the rain, we're still pushing 80+ degrees here in mississippi.
Old 07-18-12, 05:34 PM
CasualJoe's Avatar
Received 189 Upvotes on 169 Posts
At least being without a-c isn't an emergency in milder weather. I think you should post in the air conditioning forum, there are real a-c gurus in there who do this type of work every day who will help you.
Try this link, I think it will get you to the proper forum.
Air Conditioning and Cooling Systems - DoItYourself.com Community Forums
Old 07-18-12, 05:48 PM
D
Received 2 Upvotes on 2 Posts
What are the red wires connected to? maybe you have a bad capacitor,most A/C units have a dual capacitor.
Old 07-18-12, 06:04 PM
B
very true. very glad we're not in the high 90 or 100 degree days.
thanks for catching the mispost! honestly in my rushing, i just saw "A/C" and went with it--completely not noticing it was "A/C D/C"
the red wire is connected to the white side (looks about 10Ga) of the a/c coming from the breaker right outside the access panel and going to the contact.
Old 07-18-12, 09:26 PM
B
ok, an update that may spark a thought.
i turned off the outside breaker when i took the access panel off to take a peek. i just thought about going to see if the contact pulled in when the tstat was switched to cool after a long day at off. it in fact did, and that is apparently the click i was hearing.
the power is still off at this point, so i thought for the sake of experiment i'd throw the breaker to on. when i did, both the fan and compressor tried for about .9 seconds to start, then just back to the faint hum i described earlier. so, at least momentarily, the fan got power to spin it, and the compressor got power to try to start it.
is there any chance that points to something obvious to you guys?
thanks!
Old 07-19-12, 12:48 PM
B
in the way of closure for any future references, i went back out a little bit ago and poked around some more.
i fixed the burned a/c (not to be confused again with ac) feed i mentioned earlier, and tried the contact test again. this time i still heard a click, but i didn't see the actual contacts move like i did last night. hoping for the best, i pulled the contact out after calling around for a replacement. when i got it out however, i noticed what looked like 6 little legs around one of the two contact points. one paperclip later, i removed some kind of small insect that was in the wrong place at the wrong time two nights ago. "skeptically optimistic" i put it back in before going to get the replacement, and all is well.
Old 07-19-12, 12:55 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Yep....that's more common than you think. I've heard bugs, leaves, other debris. Always wondered why they don't enclose the thing a bit. More often it's just burnt contacts or a faulty coil on the contactor. Since you heard the click...wasn't likely to be the coil.
