My a/c turns off
Old 07-27-12, 07:09 PM
F
My a/c turns off
My indoor and outdoor unit turn off and the thermostat still says "cool on" and sometimes the a/c will turn on for couple seconds and turn off, again with "cool on" still showing on thermostat.
When the a/c turns on it blows cold air as normal.
Can anyone help me with this problem?
Old 07-28-12, 04:29 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
There is likely a wet switch or float switch or possible a condensate pump switch that is shutting everything off. Check for a drain pan under your furnace/coil and I bet it is full of water. If you have a condensate pump I would guess that it needs cleaned. These are the first things I would check.
Old 07-28-12, 11:11 AM
C
A/C, Fan and Heater shut off after minutes
Can anyone shead some light on this issue?
Old 07-28-12, 12:45 PM
F
hvactechfw,
Thanks for the help. The drain line was clogged causing the float switch to turn off the system. I sucked it out with a shop vac and poured some chlorine down the pvc pipe and that did the trick.
Saved me a service...thanks
