Air Handler Issue
Old 07-29-12, 02:49 PM
E
Air Handler Issue
I have attached pics of my recently installed Air Handler (Was installed by a contractor). I am showing these as I believe the second set of drain pipe connections, which have had there cap removed should be closed off, but I would like to confirm. My A/C becomes unable to cool past 78 degrees in the hot afternoon. I am thinking that because these holes suck in a massive amount of hot air from my attic it could be mixing with the return air and dampening my ability to cool.
Let me know.
Thanks,
Name:  AC Close.jpg
Size:  24.3 KBName:  AC Far.jpg
Size:  31.9 KBName:  AC Mid.jpg
Old 07-29-12, 02:59 PM
E
If its not getting the house cold, it is because there is a problem unrelated to this drain line. If you insist it is, put a piece of tape over it and wait and see.
Old 07-29-12, 03:05 PM
E
It does get cold, but in the late afternoon, it no longer can cool past 78 degrees, so the house steadly goes up to ~81 degrees. I was assuming this was due possibly to HOT air being sucked in from these two inlets. As I know the airhandler can only cool delta of the return air. So if the 100 degree air was mixing with the return air I would have VERY hot air that is being cooled rather then the homes return air.
Perhaps a more basic question is upon install do you plug up the unused drain inputs? As I do not use my vertical set (which suck in air), should the contrator have plugged them due to its attic location?
Old 07-29-12, 06:49 PM
E
Should he have plugged up a hole that sucks hot air from the attic and puts it into your house? Let me check the manual... Ya the manual says he should have.
Old 07-31-12, 02:41 PM
E
Thanks Ender that was all I need to get the courage up to tape the hole. House stayed 78 for the past 2 days now : P Angie's list will get my opinion of his work now :P
