Air conditioner cover
Old 08-01-12, 07:28 PM
Ok, This is probably a pretty stupid question, but my AC unit is seeping water into my house and I am trying to get into see it the drain is clogged. I just cant get the front panel off because of the lines running across the face of the unit... any ideas?
Old 08-02-12, 04:43 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
cut pipe between the coil and the tee above the drain trap. Use a union and glue when putting it back together so you can take it apart again if necessary.
