A/C Sealant
Old 08-08-12, 06:12 AM
Received 1 Upvote on 1 Post
A/C Sealant
It seems every year I need to add some freon to my AC. I have noticed there is a sealant available. I'm wondering if anyone has any experience with these and what their results were.
Thanks,
Steve
Old 08-08-12, 06:31 AM
Received 1,267 Upvotes on 1,207 Posts
Not an HVAC guy but I would not use it - I can see it gumming up things you don't want. I would have someone find your leak and go from there.
Old 08-08-12, 03:50 PM
E
Bad. very very bad. Your system has a leak but at least it runs. The sealant will most likely destroy the system making it not work what so ever. Not to mention no hvac tech will touch the system with that in it.
Old 08-09-12, 12:23 AM
user 10's Avatar
Received 57 Upvotes on 50 Posts
It's my understanding that those sealants work by hardening in the presence of moisture in the air.
If the original installer didn't do a very good job of evacuating the refrigerant lines and coil, adding a product such as superseal carries a risk of hardening where it shouldn't and trashing the system.
That being said, if your system is 20 years old and not worth a $500-$1000+ repair, a sealant might fix the leak and buy some time.
