AC needa outdoor trap
Old 08-11-12, 06:45 PM
R
Hello everyone:
I moved into a house where the AC drainage pipe comes out from an exterior wall int the ground. I had to dig a hole in order for me to free the pipe. The piece of PVC is about a foot long. Someone that saw this told me that I needed to put a trap there. This trap will go up and then down.
Should I do that? Somehow it makes sense but how would it drain.
Thank you in advanced. Rafael
Old 08-12-12, 04:40 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
no need for a trap at that location. A trap (if needed) should be installed near the evap coil.
Old 08-12-12, 04:50 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Thumbs up Welcome to our forums!
I might add that the necessity of a trap could depend on the location of the evaporator coil.
The coil is normally installed on the upstream side of the coil where a trap would prevent air from being drawn through the drain.
A less common location for the coil is after or downstream of the fan where there would be air pressure exerted on the drain making the drain function properly without a trap.
