ClimateMaster A/C comes on then turns off
Old 09-15-12, 03:28 PM
ClimateMaster A/C turns off after starting
My ClimateMaster A/C comes on for a minute or two and cools then the compressor turns off and the A/C stops cooling. The fan works the whole time, but the compressor won't restart after it stops. I live in a condominium apartment building and my A/C works off a water cooling tower. I checked the capacitor and it is ok. My ClimateMaster is Model: GRV042AGC30CLTS
Serial: D10422845.
Could you please let me know what could be causing my A/C to stop working? Thank you for your help!
Old 09-15-12, 06:13 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Did you measure the capacitor with a meter or only visually inspect it?
Most Climatemaster units have 2 test terminals that can be jumpered for a few seconds to display error codes.
Old 09-16-12, 06:46 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
sounds like a water flow issue to me, but you need to check for error codes.
