heat pumps maintenance
Old 09-24-12, 02:24 PM
Is there anything you need to do maintenance wise to prepare heat pumps for winter usage?
For example, during summer, you need to ensure the drain is unclogged.
for winter, does heat pumps even produces condensate at all and use drain pipes?
Old 09-24-12, 04:52 PM
hvactechfw's Avatar
Check and or replace your filter. Ensure the outdoor coil is clean. Ensure the indoor coil is clean. They do not produce condensate in the drain pipes during the heating season. They will freeze the outdoor coil and go through defrost cycels.
