Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Air Conditioning and Cooling Systems
Reload this Page >
ac will not turn on. turned it off the other day, and now no nothing, it clicks
Old 09-27-12, 06:37 AM
D
WE have a janitrol unit, just changed the thermostats not too long ago, so I thought the batteries might be the problem. changed them out, and no change.
what is next to check, checked the breakers, inside and out, no change..
this unit has been a great unit, but do not know what chould be the problem.
Old 09-27-12, 06:53 AM
N
Received 20 Upvotes on 18 Posts
Welcome to the forum.
How old is the AC unit?
Does the fan come on when the t-stat requests cool air?
Double check the breaker. Flip it off then back on. If you did only a visual check, you might have not noticed that it was flipped partially.
Old 09-27-12, 06:57 AM
W
Received 60 Upvotes on 52 Posts
Fuses
Do you have cartridge fuses on the wall outside near the outside unit? If so, these fuses could be bad.
