Old Lennox unit not working!??
Old 09-30-12, 09:18 PM
Hi guys I'm trying to fault find what's wrong with my old Lennox exterior central heating cooling unit?
The wiring diagram states its a
HS10-263v-2M,
HS10-263v-5M,
HS10-413v-2M,
HS10-413v-7M
First I've checked to see if there's voltage getting to the unit which seems to be ok!
Next I depressed the contactor on the unit a few times which I seemed to get a minor response from the compressor which sounded like it may be trying to turn over.
After trying that a few times that stopped and now what seems to be completely unresponsive when I press the contractor in.
Is the compressor broken?
Any information would be highly helpfull thanks guys.
Old 10-01-12, 04:27 AM
hvactechfw's Avatar
is your capacitor swollen or bulged on top?
Old 10-01-12, 10:28 AM
I'll take another glance over it tomorrow, is that the fan motor capacitor?
What do you think it could be?
Old 10-01-12, 02:16 PM
user 10's Avatar
Does the fan run when you depress the contactor?
Old 10-01-12, 03:10 PM
Hey guys had a play with it this morning removed the top fan today to see if I could get to the capacitor looks like I have to take the fan completely out of its housing to inspect.
No I'm getting no action from the fan whatsoever I'm assuming here there going to be a few factors involved
Old 10-01-12, 03:19 PM
hvactechfw's Avatar
http://0190acd.netsolhost.com/manuals/HS10_Series.pdf
page 6 shows the capacitors by the control box which is accessible behind the access panel.
Old 10-01-12, 03:29 PM
photos
hers some piucs of the unit
Old 10-01-12, 03:44 PM
hvactechfw's Avatar
That looks like your unit is 3 phase (not common on residential equipment). If this is the case then you will not have a capacitor for the compressor. You will have one for the fan motor. Most likely, by your description, you have 1 leg without power. Check all fuses and voltages.
Old 10-01-12, 03:51 PM
I beleive the house is on 3 phase powe. Does the service manuals show what voltages should be where. I'm pretty good technical and electrically just haven't approached aircon before.
As far as fuses are concerned ill check these also where would they be located? The house fuse box?
Old 10-01-12, 04:09 PM
hvactechfw's Avatar
That would be located on the unit. Most likely it is 208/230 3 phase.
Old 10-01-12, 05:12 PM
Having some issues locating the fuses any idea why they would look like
Old 10-01-12, 05:36 PM
hvactechfw's Avatar
Is there a disconnect switch on the house?
Old 10-01-12, 06:00 PM
There is a power on off switch on the wall. Will this be fused will it?
Old 10-01-12, 06:27 PM
hvactechfw's Avatar
post a picture please.............
Old 10-01-12, 10:24 PM
Are the capacitors safe to handle and remove?
Old 10-01-12, 10:27 PM
hvactechfw's Avatar
Stop! Please call a pro. This is the best advice I can give you at this time.
Old 10-01-12, 10:32 PM
I been an elec tech for 15 years bud I just know capacitors can hold a charge
Old 10-01-12, 10:35 PM
I usually repair tv's lots of capacitors
Old 10-01-12, 10:38 PM
hvactechfw's Avatar
No offense... you didn't know the unit was 3 phase. You don't have a clue where fuses might be.
It is not a capacitor issue as I have already told you once I learned it was 3 phase. I find it hard to believe that a 15 year electrical tech has not checked voltages.
Old 10-01-12, 10:45 PM
I can see how that might look I'm Just a noob when it comes to aircon.
Thats fine mate il work it out.
Appreciate your help anyway
  #21
Old 10-02-12, 12:57 AM
Ok
bit more investigating whether your interested or not, fan now turns over when contactor is pressed in and im getting 242 v on all phases, when contactor is not pressed im on getting 92v on phase 2.
i also open up the dissconnect switch couldnt see any fuses have attached photo.
  #22
Old 10-02-12, 01:36 AM
ray2047's Avatar
Your IP address indicates you are Australian. Is that correct? Please fill that out in your profile. This is primarily a North American board and the people answering questions may not be familiar with your exact equipment.
  #23
Old 10-02-12, 03:56 AM
can anyone fill me in on some information regarding attaching a 24v power supply to this unit?
