AC/heater has no power
Old 10-05-12, 06:06 PM
D
Hello,
I have central AC/heater unit. About a year ago, it stopped blowing hot and cold air but it would still blow air. I got someone from ASI took look at it. Aside from taking my money for simply coming out, he did something to the fuse (I thinh he flipped it) saying there's no point in giving it power if it's not working. I went back today and flipped the fuse and tried to turn the heater/AC on and it doesn't come on. Anyone know why that is? How can I get power back to the unit?
Old 10-05-12, 07:28 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
need to verify power into unit and out of transformer.
Old 10-05-12, 09:25 PM
D
how does flipping the fuse cut off power to the transformer?
Old 10-05-12, 09:29 PM
hvactechfw's Avatar
how do you flip a fuse? Now that is a good question!
Old 10-05-12, 10:20 PM
D
there are 2 fuses on a fuse block. he took the block out, turned 180degrees and put it back. basically he disconnected the fuse block.
Old 10-06-12, 05:38 AM
hvactechfw's Avatar
Ok, you are talking about a pull out disconnect. Now I understand. Have you verified that the breaker is on? Have you verfied the fuses are good ( in the disconnect)? Have you verified power into and out of the disconnect?
Old 10-06-12, 02:07 PM
D
if by breaker you mean circuit breaker, yes i checked that. how do i check for good fuses? how do i verify power to the disconnect?
again, i don't understand how these things go bad by flipping the fuses.
Old 10-06-12, 03:21 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
How? Did you turn it all the way off then back on? Sometimes they don't look tripped but are. Did you use a multimeter or test light to test the voltage between the two breaker lugs and from each lug to neutral?
Pull the fuse and check for continuity with a multimeter.
They don't.
