Water Furnace Spectra No heat
Old 12-13-12, 10:02 AM
H
The display on the stat got too dim to read, so I changed the two AA batteries in the stat, now the heat fails to operate. The fan will run on manual. The Aux heat will not operate. There are two flashing green leds in the unit.
I could not find a fuse or reset button, it there one?
I did fail to change the batteries properly, its suppose to be one at a time and I removed both and replaced both at the same time.
Old 12-13-12, 06:23 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
Old 12-13-12, 09:09 PM
H
Houston204
Thanks for taking the time to provide the link and pinpointing the pages for me. It turns out to not be the t-stat I have. Mine is Maple Chase 0962 and does not have the features mentioned in the manual, for example, I do not have a mode button.
I have checked the power sources as being there.
I'll continue to surf.
Thanks
Harry
