Switching from a three wire motor to a four wire motor
Old 01-16-13, 08:44 PM
Hi all,
I was just curious if anyone could help me. I purchased an AO smith motor with 4 wires to replace my three wire GE motor. On the original motor the 1) Purple wire was attached to the C pole, the 2) brown wire was attached to the fan pole on the capacitor and the 3) Black wire was attached to a curicuit board. (it's a heat pump.
The New motor has 4 wires black and white which the diagram says go to line and are reversible, a brown and a brown with white stripe.
The Grainger tech told me to attach the brown to the fan pole as before, attached the black to the relay on the printed circuit board as before, the brown and white stripe should not be used and the white wire should go to the C pole on the capacitor.
Help
Philip
Old 01-16-13, 08:47 PM
just wanted to add that its a Trane 14i heat pump...
Old 01-16-13, 09:59 PM
Received 4,088 Upvotes on 3,671 Posts
A part number of the AO Smith motor would probably be immensely helpful.
Old 01-17-13, 08:13 AM
Ok sorry, the new motor is an AO Smith #FE1028SF
Old 01-17-13, 08:17 AM
This is what the wires looked like before I removed the old motor and dual run capacitor
Old 01-17-13, 08:37 AM
Size:  34.2 KBName:  002.jpg
Size:  32.7 KBAnd this is what the tech told me to do (which I did with no success). The compressor runs but not the fan with it this way...
Old 01-17-13, 03:38 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
You have the new motor wired correctly. It sounds like a defrost control board issue. Did you check voltage to the motor before replacing the motor?
Old 01-17-13, 06:02 PM
Final result
Well after much consternation I was able to determine what the problem was.
I could not understand how the motor was not running and even went to get a second capacitor for just the motor thinking that the motor might not run as a 3 wire set-up.
I hooked the Brown and Brown with white stripe to different terminals on the motor Capacitor, the black to the printed curcuit board with a relay (I found out later this is the, "defrost board." Still all I got was the compresser and not the motor.
Then, I though that the defrost board relay might be stuck so I took the black lead off the relay on the board and the whole relay came right off the board. I still took the black wire and connected it to the black out side of the line to confirm my suspicions and the motor worked fine.
I then very carefully re-soldered the relay back onto the "defrost" PC board and voila, it worked like a champ... Problem solved now its Miller time
Old 01-17-13, 06:12 PM
So, thank you Mr. Moderator for hitting the nail on the head and pointing my snout in the right direction
