for Air cooler, help me please!!
Old 01-29-13, 02:20 AM
G
Hello,
We have an air chiller unit. The block diagram and orginal device's foto are available in the attachments.
What do you think of the structure of coolant???
Thank you in advance...
Old 01-29-13, 08:29 AM
Received 4,082 Upvotes on 3,665 Posts
Welcome to the forum from Turkey.
Not sure what your question is.
Are you asking what is inside that internal structure ?
It looks to be a refrigerant coil with a blower.
Old 01-29-13, 10:51 AM
G
thank you for interest...
The values in the image to be able to make a cooling of the internal structure of how it should be?
Standard unit evaporators with could not.
Is it must be in the cabin heat exchanger or evaporator? Which one?
How should the shape?
I can not make enough cooling and air flow!!!
Old 01-29-13, 11:01 AM
G
Soryy!!!
The following figure looks at the air stream is incorrect.
Not Air flow rate(air outlet) : 110l/m
This is the value that must be... Air flow rate : 1100 lites/minute (air outlet)
Old 01-29-13, 08:21 PM
That evaporator is designed to extract a certain amount of heat from the air that is passed thru it. I'm not a design engineer but that's who would design that system. You may be able to increase airflow thru the coil but it may have a negative effect on the overall system.
