A/C won't cool unless I turn breaker off and turn back on, heat pump unit
Old 04-24-13, 06:36 PM
R
I've searched and searched but have not come across this situation. Thermostat set at 77, ambient temp 81, air handler in the attic blowing warm air, compressor and fan outside on roof not running. Fuses good, breaker not tripped but when i turn off breaker and turn it back on everything comes on after a time delay of a few minutes and blows cold. Once the house cools down, unit cycles off, the next time it calls for cooling the only way to fire the compressor off again is to go out and turn off the breaker and turn it back on again. Keep in mind, the breaker never trips. I even replaced the breaker because it was bugging me! Has anyone come across this situation? Any help would be great!
Thanks,
Gary
Old 04-24-13, 06:42 PM
Received 1,019 Votes on 946 Posts
Welcome to the forums.
I go out and turn off the breaker and turn it back on again
Is this the breaker on the compressor unit....... not the air handler ?
Two things that come to mind are the contactor or the defrost board.
A make and model of the compressor would be a big help too.
Old 04-24-13, 07:30 PM
R
Compressor breaker.
Bryant 602A package is all I know
Thanks, Gary
Old 04-25-13, 04:24 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
Sounds like the system is shutting down on a safety and you need to find out what is tripped instead of simply resetting the control board by cycling the power.
Old 06-19-13, 10:06 PM
T
Same problem
I'm having the exact situation. What did you end up having to fix? Thanks, Tammy
Old 06-19-13, 10:58 PM
It may appear that you have the same exact problem but the repair could be different if the units are different.
Do you have a heat pump system ?
You either need to check the pressure switches in the compressor or have an HVAC tech do it.
The unit could be low on freon. It could have a condensor fan issue causing the unit to run hot.
Old 06-20-13, 03:51 AM
hvactechfw's Avatar
Tboisvert... please start your own thread so we can help you with your problem. Similar problems usually have different causes and to avoid confusion we would prefer a separate thread. Thanks!
