no cooling - wrong thermostat?
Old 04-24-13, 08:45 PM
My A/C blew air only a couple degrees colder than the return air. I disconnected the red wire from RH terminal by removing the jumper between RC and RH. A/C works fine now (temperature difference is about 15 degrees). So, I don't have heat now (it's OK for a next few months) but how can I fix this for good?
Old 04-24-13, 11:32 PM
Received 337 Votes on 315 Posts
Welcome to the forums.
A little more information would be helpful. Make and model of heating system.
I'm guessing a heat pump with electric reheat coils.
So right now the red wire is just on RC and nothing on RH...... correct ?
It would almost suggest a thermostat problem.
In your post you ask if it's the " wrong thermostat" .... why.....was it recently replaced ?
Old 04-25-13, 05:43 PM
It's Goodman AEPF air handler with single-stage cooling, heat pump and emergency heating.
Yes, red wire on RC and nothing on RH.
The thermostat White-Rodgers 1F95-1277 had to be replaced just after the installation about 4 years ago because of the same problem (according to the installer "cooling and heating was running at the same time").
Old 04-25-13, 08:53 PM
hvactechfw's Avatar
sounds like the thermostat failed if removing the jumper fixed the problem..... You may want to replace it with something other that WR..... I would use a high end Honeywell. A high end Honeywell will at least have a 5 year warranty instead of a 3 year that the WR had.
