2 year old goodman ac unit very stinky
Old 04-30-13, 04:10 PM
stinky ac unit's Avatar
hello i have a two year old a/c unit made by Goodman . it has this nasty raw fish smell when ever i first turn it on after it sits for a day . what could this be ? GI2
Old 04-30-13, 04:39 PM
Received 1 Upvote on 1 Post
Dirty coil. plugged up condensate drain.
Old 04-30-13, 09:33 PM
but it drains into my back yard when i turn it on ?
Old 04-30-13, 09:47 PM
Received 4,105 Upvotes on 3,687 Posts
Welcome to the forums.
It may drain when in operation but it may also be holding too much condensate. A partially clogged drain is not out of the question.
The condensate tray may have to be cleaned with bleach.
Old 05-01-13, 12:54 AM
ok thanks i will look at it in the morning . where is this tray in the ac unit ?
Old 05-01-13, 07:16 AM
It's in the air handler section. Hard to say for sure exactly where it is in your unit since we don't know what unit you have. You should see the drain line for it on the outside of the unit.
Old 05-01-13, 05:06 PM
i found the pan and it had a small amount of water and was fairly clean . i dumped the water out plugged the hole and let it soak in bleach for an hour . then put it back in went in side smell seemed to be gone . then i just got home an hour ago turned on the a/c and now the raw fish smell is stronger . as for the coils i don't even know how to clean them . im starting to think something got in there and died .rogram:
Old 05-02-13, 03:55 PM
ok i had a a/c specialist come out he cleaned the coils but had to wait for a hazmat team to come out from his company . he found a dead cat in there . im hoping this gets rid of the smell .
Old 05-02-13, 07:23 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
A DEAD CAT?! Been there and done that! It is not pleasant. Was it your cat?
Old 05-02-13, 09:19 PM
no not mine i have not have any animals for about 4 years . it must have belonged to some one close by it had a name tag but no address ,
Old 05-02-13, 09:23 PM
A
O.K. Maybe a stupid question but exactly how does a cat get into an air handler?
Old 05-02-13, 11:52 PM
the vents are just big enough for them to get into the unit .:bad poster:
