system running when it shouldn't?
Old 05-12-13, 01:58 PM
R
Ok nothng wrong with my ac or the unit everything works however my unit outside turns on while everything inside is good temp set to 78 temp is 78 set to cool so the unit outside turns on for maybe ten minutes and then shuts off why is this any response would be greatly appreciated
Old 05-12-13, 02:21 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Today's digital thermostats actually read in tenths of a degree. Just because your thermostat says it is set at 78 doesn't mean that it actually is. It may be 77.5 which is causing to turn on and maintain a temp of 78. It is designed to keep within .5 degree instead of the old stats that required a full 1 degree of droop before activating. If you system is only running for 10 min then you either have a light load on your house at that time of your system is oversized (possible, but unlikely)
