Frigidaire AC window unit thermostat broken?
Old 05-18-13, 02:20 PM
T
I have a 7-8000 BTU Frigidaire AC window unit in my bedroom with a digital thermostat and remote control. It is stuck on fan only and will not turn off unless I unplug it from the wall. When I plug it back in, it goes back to fan only with them all whirling at normal speed. I can't turn it off otherwise or change any settings. The remote does nothing. Pushing the buttons on the panel does nothing. The display is forever set th 79degrees. I don't know if the cooling part of the AC is broken or not, since it hasn't gone above 79degrees in my room yet, but with 100% humidity I really would like to turn it on anyway. Is the digital thermostat broken in the unit? Can it be easily fixed or replaced?
Old 05-19-13, 12:53 AM
Received 4,119 Upvotes on 3,699 Posts
Welcome to the forums.
Can the board be easily fixed or replaced.
I repair the boards but I work from experience. There are no schematics available for the control boards. They can be replaced if they are still available.
If you leave a model number I can check further for you.
