Lennox xc15 condensing unit wont turn on
Old 05-21-13, 12:57 PM
R
i hav e alennox xc15 unit and niether the fan or compressor will turn on. I have power into the unit, but none of the indicator lights are lit on the diadnostic modular.
any help?
Old 05-21-13, 08:09 PM
Received 3,891 Upvotes on 3,488 Posts
Welcome to the forums.
Do you have any power to your furnace/air handler ?
Did the power/service switch get turned off ?
Does the furnace part (if it has one) work.
Does the inside blower work if you put the thermostat in FAN ON mode ?
Old 05-21-13, 10:29 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
As PJ has already posted start with the light switch by the furnace.
If that switch was already on and the indoor fan does not work as well as the outdoor unit, check the low voltage wires outside by the unit for damage.
Many Lennox furnaces have a low voltage circuit breaker instead of a low voltage fuse. Usually pops up when tripped. I wish every brand used them.
