Replace outside Air Conditioner Condenser unit
Old 05-21-13, 03:06 PM
Hello, last year I had a gutter come down and land on the AC copper pipe that goes into the Air Conditioner Condenser and I think it broke the the pipe and the AC doesnt work anymore or run for that matter. The condenser was super old and I wanted to replace anyway. Can I just replace the 2 ton Air Conditioner Condenser and thats it? Thanks!
Old 05-21-13, 03:26 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Nope.... You could have a new R22 condenser put in, but it would cost you a LOT of $$$ for the R22. The SMARTER thing to do would be to replace the SYSTEM (condenser and air handling unit/ evap coil) with a R410A model. R22 is going away and the cost for R22 is sky rocketing.
Old 05-21-13, 03:31 PM
Dang I was afraid of that.... Is there any great DIY sites I can get started with install instructions? I did find THESE but like a lot of options... Thanks!
Old 05-21-13, 04:11 PM
hvactechfw's Avatar
NO, and YOU can NOT install it on your own, you can do the grunt work but you will need a professional to come and pull a vacuum and charge the system properly with refrigerant.
