Capacitor for Condenser Unit
Old 05-29-13, 07:38 PM
WRDIY's Avatar
Received 2 Votes on 2 Posts
I am helping my sister by changing a new capacitor for her AC unit.
I have a couple of questions:
1st, is it normal for a capacitor to be installed upside down with the prongs facing down?
2nd, can you help me locate the correct capacitor for her AC. I attached pictures but could not read the original capacitor.
Thanks
Old 05-29-13, 07:46 PM
user 10's Avatar
Received 41 Votes on 35 Posts
40mf + 5mf, 440v
mf = microfarad
It's a dual capacitor; both values have to match.
Are you sure the capacitor is bad? Fan motor which needs a little push to get going or compressor which won't start indicate that the capacitor is bad. (other things can cause the compressor not to start)
Old 05-29-13, 09:17 PM
WRDIY's Avatar
The entire unit is fine. the unit is over 20 years old so I just thought I change it before it goes bad since I am planning to put a hard stay kit too.
Could you explain more about both values have to match? Do you mean 40mf and 5mf?
Thank you
Old 05-30-13, 12:42 AM
Received 1,029 Votes on 955 Posts
Yes.......
It's a dual section capacitor. It will have both ratings on it just like the one in your picture. It will have three leads. The voltage capability of the unit is 440 vac.
Old 05-30-13, 03:39 AM
WRDIY's Avatar
Ok, I will look for it on Amazon and post back here just to verify. Thank you
Also, back to one of the questions. Is it right that the capacitor was installed upside down?
Old 05-30-13, 11:34 AM
WRDIY's Avatar
Is MF the same as MFD?
This one is awfully cheap. Does price matter to quality?
Aviditi 38AVI Capacitor, 40/5 Microfarad, 440-Volt: Amazon.com: Industrial & Scientific
Here are some more:
Amazon.com: 40 5 440 capacitor
Old 05-30-13, 06:16 PM
hvactechfw's Avatar
dont change it unless it is weak.... they don't make capacitors like they used (they don't last as long today)
Old 06-27-13, 11:14 PM
WRDIY's Avatar
HVACTechFW, I took your advice and replaced it with the exact same model.
