Honeywell Deinite Purpose Relay Contactor replacement w/Protech
Old 06-19-13, 09:13 AM
R
Hello
I have a UAMA036JAZ with an older definite purpose Honeywell 1 pole realy contactor. In the search for the replacement contactor the OEM part from protech. The Honeywell is a single pole with L1 and T1 and confusingly and L3 and T3. The Protech has an L1, T1, L2 and T2.
When replacing this Honeywell can the L3 be run to the L2. There are only two wires currently te black L1 and the white on L3. I dont understand why the Honeywell has labelled this as L3 when it should be L2. Also does the common conductor C1 and C2 get mapped to A1 and A2 on the Protech?
Thanks for any advice in advance.
Old 06-19-13, 11:59 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Post the model number of both thermostats or post some pictures...
Old 06-19-13, 02:52 PM
R
Here is the old relay. I hope you can see it
Old 06-19-13, 03:23 PM
R
And this is the new one that is the replacement
Old 06-19-13, 06:35 PM
Received 1,042 Votes on 966 Posts
The contactors are electrically identical.
Hold them both the same direction as the pictures and reconnect to the identical same places. One difference is the low voltage wires go one on each side instead of both on the same side.
Old 06-20-13, 10:45 AM
R
Thanks. I am going to try that. I think the old one has an error in the line numbering.
Old 06-21-13, 07:16 AM
R
Replaced the old Honeywell R8242 with the mislabeled t3 and l3 to the t2 and l2. The wires had to be moved around but it was easier for me to think of the two lines and see what jumpers were then attached to those lines and reconnect it in that fashion.
Thanks PJMax for your help!
Old 06-21-13, 10:55 PM
You're welcome. Glad you got it working.
The point I was trying to make was ignore the lettering/numbering as long as the wires ended up in the same locations you'd be ok.
