Carrier AC Unit
Old 06-19-13, 01:19 PM
Carrier AC Unit
I need to replace the A-coil for my Carrier AC unit. The HVAC tech said I could find one cheaper and he would install it. The AC unit's model number is 38eb030311. The A-coil's model number is 28ar030021. How many ton is my unit? It uses r22. Any suggestions on a replacement part? Cased or uncased?
Thanks!
Mark
Old 06-19-13, 06:42 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
It is 2 1/2 ton. Good luck finding an R-22 evap coil these days.
Old 06-19-13, 07:52 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
You are much better off in the long run to consider replacing the entire a/c system.
Old 06-20-13, 05:00 AM
Thanks Grady!
Replacing the entire system may be the answer. Thanks for the help!
