Is this my condensate pipe?
Received 0 Votes
Have a leak in the garage when AC runs. And I learned from here to vaccume the condensate pipe. I have my wet vac ready, is this my pipe though? Doesn't seem like any water is running out but the AC is off.
Most likely...unless you water heater is right there as well. (I think the WH may require copper...so likely it isn't that.) If you have a leak in the garage...either a pipe joint wasn't glued right or the pan is overflowing and somehow leaking in to the garage.
Received 0 Votes
It hasn't leaked within the 2 years I lived here. I walked around the house and can't find any similar pipe so I'm going to assume this is it.
As far as water heater goes (I know this is the wrong thread) any maintenance I can do to it like my AC pipe. I'm going to try to vacuum it, no harm if it's not my condensate pipe right?
Thank you for the replies!
No harm at all. If the house is newer...then draining and flushing a WH is always a good idea. If it hasn't been done in years and years...then best to leave well enough alone and start the maintenance when the replacement is installed. Newer gas heaters DO need to have the screen for air inlet cleaned or it can lead to shutdown issues.
EDIT...don't forget to look up when you are looking for another pipe. Had a member just recently with the primary way up at the edge of the roof and the secondary at ground level.
Received 0 Votes
Would it help if I had the AC on when I vacuum the pipe? Doesn't look like anything is coming out.
There's another small pvc pipe next to the ac part in the garage, it's in an L shape with a lid at the elbow that when I pull the lid water comes out. Is that what I need to vacuum instead?
Or continue to vacuum from the outside until it's free?
the best thing you could do is cut the pipe closer before (closer to the furnace) then the plug. Be prepared with a bucket to catch the water. Next glue on a 3/4" PVC union for future servicing. Next blow though the pipe (with plug still in place) to clear the blockage.
Received 0 Votes
Okay, coat hanger straight down and to the right didn't show any debris. I let all the water flow out. Hanger outside didn't reveal anything. Do I vacuum inside the garage or try again with the outside pipe?
Should I turn the AC on and see if water comes out of that outside pipe?
Received 0 Votes
This is weird, I got a cheap snake and pushed the obstruction so now the main drain is clear. I poured 1/3 part bleach 2/3 part water down and it went down. I go outside to what I assumed was the condensate pipe to see water get flushed through but nothing came out. Do you think I just pushed the clog further into the pipe?
Assume I should vacuum what I assume is the condensate pipe from the outside then?
If you felt an obstruction with the snake, you probably did just push it further in. When you snake the pipe, you need to go completely through the pipe to push the obstruction completely out of the pipe. The exception would be if you have a snake with a "drill" at the end that you can twist and it breaks up the obstruction. Once the obstruction is either removed or broken up, you should be able to get water to pass through the pipe.
