AC Fan not starting.
Old 07-16-13, 09:45 PM
schutzengel
I have a RUUD UBEA-17J10NFFAI Air handler the will not start, I have 220 coming into the unit and the float switch is closed, it was tied in series to the red thermostat wire and has less than 1 ohm of resistance. Where and what do I check next?
Old 07-17-13, 04:39 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
does the outdoor unit run?
turn the fan to ON at the thermostat... does anything happen?
Old 07-17-13, 05:21 AM
schutzengel
from the thermostat no,
I have to push the contactor down in the outside unit to start it but it does run
