condenser motor problems
Old 07-17-13, 07:35 PM
G
I have an older lennox unit model # CB5185139. the fan motor is going bad and I need to replace it. The # on the motor is K55HXJRH 3601. I am having a very difficult time finding the proper replacement motor. the spec are: 208-230 volt amp1.1, 1/6 HP, 825 RPM, 1/2" shaft dia., 5" long shaft, clk wise rotation face up, closed face (no ventilation slots), approx 5 1/2" motor diameter to fit in mount. Any help on how to find a match ASAP would be great.
Old 07-17-13, 08:59 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
Old 12-28-13, 11:29 AM
H
Lennox cooling fan stops working after normal start
I have replaced the fan motor, start cap, and control board on the outside unit. The systems starts, then after 1.5 minutes the cooling fan turns off.
Any thoughts?
Old 12-28-13, 11:32 AM
Received 4,046 Upvotes on 3,630 Posts
Welcome to the forums.
This actually needs to be its own thread.
Is your Lennox a heat pump system ? It may be going into defrost mode which turns the fan off.
A model number of the unit would be helpful.
