Air conditioner unit flooding side yard
Old 07-18-13, 01:47 PM
K
Name:  2013-07-18 16.38.00.jpg
Size:  51.0 KBName:  2013-07-18 16.38.17.jpg
Size:  50.7 KBName:  2013-07-18 16.38.38.jpg
My air conditioner seems to be flooding my side yard.
Help?
Old 07-18-13, 02:48 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Air conditioners produce condensate from the indoor coil. It drains by way of a pipe...the grey one to the right of the unit I'd guess.
When it's hot and humid, it can easily produce 5 gallons a day or more.
If I'm seeing the pics right, looks like you have very hard soil as well as a depression around your outside unit.
Easy fix is to put a bucket under the pipe, collect the water and dump it on outside plants that need watering.
Other things would include digging a french drain right there (not recommended if you have a basement) or piping the water away to an area with a better slope and drainage. You need to keep the pipe sloped i that case as it's all gravity feed.
It's also possible that your system has a condensate pump in the pan of the upper unit and it is pumping a large amount out all at once...normally they just drip drip drip....
Old 07-21-13, 01:33 PM
K
Thanks sir, I was hoping it was just a drainage issue as that is easier to fix than not :P
I am gonna do that and see how it turns out!
