Sharp comfort touch air conciditioner
Old 07-25-13, 02:06 PM
R
Help has any one open a sharp comfort touch. MODEL Afr-125CX their are 4 screws that can not be reached inside behind the condenser coil and 4 more inside behind the plastic shroud.
Old 07-25-13, 10:12 PM
Received 4,051 Upvotes on 3,634 Posts
What is it you are trying to do ?
Old 07-26-13, 02:04 AM
R
Hello The AC unit started blowing a mist or fog, I think it was low on Freon.so I am trying to put a bullet valve on to check for pressure and vacuum leeks then a charge with some Freon.
Old 07-26-13, 02:15 AM
F
Received 39 Upvotes on 31 Posts
Unless you have the EPA certification for working with refrigerants you cannot do ANYTHING to the sealed refrigerant system. Even if you do have this certification it is the policy of this forum to give no help regarding such work.
Old 07-26-13, 06:04 AM
R
NO I am not EPA Certified. I am a Black seal Boiler Operator by trade, for the last 13 years. I am currently tacking classes for Blue Seal. one of my best friends has an HVAC License for the last 10 years or so I told him that I would have it taken apart and clean by the time he comes over. he is EPA Certified he installs and Service out door Units. I am only asking does any one knows how to open this unit.
