How do I replace capacitor on my AC
Old 07-30-13, 07:02 PM
I purchased a new capacitor to replace the old one. The problem is there are 4 wires and the 'prongs'/connections on the capacitor's are different so I'm not sure where the wires go.
# = 'prongs'/connections
Old Capacitor (Sorry about blurry image), GE Part #:97F9833
New Capacitor, GE Genteq Part #:27L877
If someone could tell me which wires go where that would be great.
Old 07-30-13, 07:28 PM
Name:  AC Frontal View.jpg
I'm not sure if it helps, but you can look at my cap in the pic to see how you would wire yours. I have a similar dual run cap.
Old 07-30-13, 07:30 PM
firedawgsatx's Avatar
I believe you have the terminals marked wrong on the top photo but the photo is too blurry to make out the markings. But, normally the brown wire goes to "Fan" and it appears in your photo the brown wire is going to the 1 terminal connection. Normally, the "C" or common will have 4 blades, the "H" or Herm will have 3 blades and the "Fan" will have 2 blades (sometimes 1). Your connections on to the replacement capacitor should be exactly the same as the original. Swap wire for wire one at a time from the original to the replacement and you should be good to go. I suggest you re-look at your original capacitor to make sure of the terminal designations.
Old 07-30-13, 09:27 PM
hvactechfw's Avatar
Brown = fan
Yellow = herm
Red and purple = C
Old 07-31-13, 05:23 PM
Here are better quality pictures of the old capacitor.
The fan has 4 terminals, herm 2, and C 3.
Old 07-31-13, 05:29 PM
hvactechfw's Avatar
ok, I already answered on how to wire it up to the new one...............
FYI, it looks as though you old one was not manufactured with the proper labels. Regardless I know you system and I know what color goes to which terminal on the new capacitor.
