replacing a blower motor for gas furnace/AC unit
Old 08-07-13, 04:04 PM
I am replacing my blower motor for my AC/gas furnace.
The OLD motor has the following:
2 brown wires that went to the capacitor;
The rest of the wires were connected on the circuit board:
Off-white (may have been white at installation 13 years ago) wire went to "Neutrals" where there are 3 connections & this one went to the one on the far right;
Yellow went to "M2" (M1 was not used)
Black went to "Cool"
Red went to "Fan"
Blue went to "Heat"
________________________________________________________________
The new motor shows the wiring as follows:
Capacitor: Brown
Brown/white (I have those done with no problem)
The rest are as follows:
White = COM Line
Black = Hi
Blue = Med
Orange = Low
Red = Slow
Green/yellow = ground.
SO MY QUESTION IS: how do I hook up the new wires? (old motor had 7 wires including the 2 that go to the capacitor and new motor has 8 including the 2 that go to the capacitor)
Circuit Board spots: I know the green/yellow is ground so I don't need help with that unless it goes into one of the following slots.
1. Neutrals (third spot to the right) = ? (maybe this is where the ground/grn/yellow goes?)
2. Cool = ?
3. Heat = ?
4. Fan = ?
5. M1 = ? (was not used with old motor)
6. M2 = ?
Old 08-07-13, 04:35 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
1. Yep, neutral
2. Black
3. Blue
4. Red
5. Not used
6. Orange
green/yellow ground wire goes to a sheet metal screw on the blower housing assembly
Old 08-07-13, 05:29 PM
So #1 is White?
The rest I understand. I thank you so very much! And yes, I reviewed the "charging air conditioner" information. I will hire a licensed guy for that but this I was trying to do myself. I know I cannot refuel the refrigerant and would never attempt to short-cut that.
