Mitsubishi Mr Slim Split AC Blower running too slow HELP PLZZZZ
Old 08-09-13, 12:17 AM
Unhappy Mitsubishi Mr Slim Split AC Blower running too slow HELP PLZZZZ
Hello there
Ive got this Mitsubishi 1.5 TON recently got it recharged as have had a leakage, now its been fixed but the cooling isnt much impressive as before it used to throw freeze through the blower and even blower runs slow like 5.5/10. Kindly help me out what to doo????????????????
Old 08-09-13, 02:38 AM
Bob14525's Avatar
Received 26 Votes on 21 Posts
One possibility is that there is insufficient refrigerant in the system. That would reduce the cooling capacity and could result in the evaporator coil freezing up, thus reducing the airflow through the system. You probably need to have an HVAC technician come out to evaluate the system. If you recently had it repaired and it's not working correctly, I would start with the technician that did the work. Depending upon how long it's been since he repaired it, he may not charge you.
