Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Air Conditioning and Cooling Systems
Reload this Page >
furnace motor recycles on and off while stat is off or completely disconnected
Old 08-19-13, 02:11 PM
C
my forced air gas furnace works fine while in heating or cooling mode. when the thermostat is in the off position, or completely disconnected, the motor sometimes goes on and off every few seconds. this might last 15 minutes to a few hours and stops. it will start up again in a few hours or a few days. it is a "bryant" 12 year old horizontally mounted attic furnace in CA.
any ideas?
Old 08-19-13, 02:50 PM
T
From afar, sounds like a fan limit on the furnace side coming on due to heat in the attic. Being only 12 yrs old, I would think it was on the board though.
Old 08-19-13, 03:09 PM
C
hi tin man,
it seems logical to point to the circuit board since this occurs even when i disconnect the thermostat. i imagine something has to be controlling the motor's action.
two questions:
1) is there a test for the board or do i have to roll the dice and buy a new one?
2) could this action be wearing out my motor?
cmo
Old 08-19-13, 03:20 PM
T
Extra wear and waste of electricity yes. I'd have to see the burner area and if it had a fan switch for furnace only to know. It sounds like it's temp. control happening, which the board would have nothing to do with. Possibly a picture of the upper half (burner area to flue) would help give more answers before buying a new board.
Old 08-19-13, 04:46 PM
Received 4,101 Upvotes on 3,683 Posts
With a model number of that unit I could probably locate a wiring diagram for it.
