Trying to install Honeywell RTH7600 over old Trane Thermostat
Old 08-26-13, 06:34 PM
I
Hello all,
Thanks in advance for any assistance provided... Im am trying to install my Honeywell RTH7600 Honeywell over an old TRANE mercury system... The problem is that the colors that are present in the old thermostat are not present in the new... I will try to post photos shortly
PLEASE HELP
Old 08-26-13, 07:29 PM
Received 4,140 Upvotes on 3,718 Posts
Welcome to the forums.
It looks like the following thread should help you out. If not let us know.
http://www.doityourself.com/forum/thermostatic-controls/466198-replacing-trane-weathertron-thermostat-honeywell-7400d.html
Old 08-26-13, 08:14 PM
I
Thanks for the quick reply PJ... im looking it over now and will try it here shortly
Old 08-26-13, 08:37 PM
I
so that forum was really helpful.. but im having a small problem... ac seems to kick on but not really blowing cool are... just blowing air... also it almost seemed to blow cooler when i turned on the HEAT..??? any ideas
Old 08-26-13, 08:50 PM
This is not my area of expertise but I remember reading something about programming the thermostat when installed in the link I left you.
Have you programmed the thermostat.
Old 08-26-13, 08:59 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
2 questions....
1. Did you program the thermostat?
2. What is your backup source? Gas or electric?
Old 08-26-13, 09:25 PM
I
I never programed the thermostat as i believe i have a traditional unit and it says that programming would not be neccessary..
just an electric unit .. no gas anywhere in the home
Old 08-26-13, 09:29 PM
I
additionally there was no black wire being used... i believe that i may have seen one in the wall but i did not use it as it was not being used prior
Old 08-26-13, 09:31 PM
hvactechfw's Avatar
You have a heat pump and not a conventional system. The thermostat must be programmed as such with aux heat.
Old 08-26-13, 09:32 PM
I
and there is a grey looking wire that i am not using either .... marked as T on the shot that i posted earlier
Old 08-26-13, 09:35 PM
I
Thanks for the info hvactechfw... how can you tell that i have a heat pump??
Old 08-26-13, 09:40 PM
hvactechfw's Avatar
The thermostat and wiring associated with it. Also, most FL residents have heat pumps and not straight a/c
Old 08-26-13, 09:52 PM
I
OK .. I will try programming the unit as heat pump please view the shot below and let me know if this looks right to you
Old 08-26-13, 09:55 PM
hvactechfw's Avatar
looks good to me...............................other than the exposed wire... those really should be shortened, but I'm particular.
Old 08-26-13, 10:03 PM
I
will do ... i think the only other question id have is according to the manual there are two types of systems with heat pumps one with out backup or aux heat and one with... how would i tell which system i have
Old 08-26-13, 10:10 PM
hvactechfw's Avatar
I already told you with aux..... post #9.... the use of aux/E terminal designates you have aux heat.
Old 08-26-13, 10:12 PM
I
AWESOME!!!!! you guys are absolutely awesome... I am up and running ... cold air is blowing like a champ..... Thank you so very much
Old 08-26-13, 10:13 PM
hvactechfw's Avatar
glad you got it!..............................
